Just went Turbo .... Tell me what you think
Sr20Det20
Car: 240SX
and when my car was runign i got great gas mil.. when i was out of boost..
Elbowblk
Car: 95 240sx
damn dude thats an awesome budget build. Im gonna try that
Jookmasta
look man, no disrespect to u nor the other poster in this thread but u honestly need proper tuning and engine management to have this car running properly 100% of the time. you're on a budget but there's only so many corners that can be cut. my suggestion is a tuned ecu, wideband, and safc. you shouldn't have to worry about timing with the ecu but if things get hairy driveability wise, you can just monitor what's going on the wideband and adjust with the safc till you figure what is f'n up. anyways, good luck with the project and she should be able to brake the 14 second barrier with a competent driver and launch.
slepys14
Car: 96 240sx se
I think that your pants are to big, you dudes need to start wearing belts!
Sr20Det20
Car: 240SX
i bought a wideband ... and a oil press gauge .... and imma send it out to pride performance bunch of my friends work there.. so they coming to tow my car monday... then imma see what i need done .... im not really on a budget i just spent 3 gs on the turbo set up and all the install and apexi neo install and dyno tune ... so i have a grand left lets see what i can do ...
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
yeah , lets... btw I was just 1dering , what turbo is "Matt's Drift Beast" using?
Sr20Det20
Car: 240SX
ok so i turboed it found out its wiring porblems so ima just sell it ... what you guys think i can sell her for ...
Zippy69
Car: 1993 240sx coupe
Man, don't give up. What plugs are you using and what is the gap set? Try a gap of .35 and see how she does.
hpmachine
Car: '05 EVO8 + '95 240sx
What kind of wiring problems are there???
Sr20Det20
Car: 240SX
i tried gapping to .35 they were gaped at .33 .... and hp idk man im guessin it is becuase my apexi neo had all my top maxes saved ....now it doesnt ...so idk what my neo did i went thru it all the map tuning is still there ... so if its my neo or what..... i have new wires and all on it ... and the head was ported and polished before turbo install .... and new head gasket and arp head studs ...
Sr20Det20
Car: 240SX
so found out whats wrong ... found out its my apexi neo brand new ... took a ****
nissanfanatic
Car: 1992 Nissan 240sx SE
480sx wrote:Every time someones tried this their car has run pig rich and like ***.
This does not work at all, idk how that got started.
It would work if you maxxed the injectors at all times. Buy an AVC-R and adjust boost based on RPM using a 50trim so that your car makes ~260whp at all RPM ranges under WOT. And don't ever lift.
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
you should of went emance tune instead of afcneo. trust me afc's are crapp.....based on my experience, afcneo work but there are just some days were it doesnt want to work right. plus apexi never did test it on a ka24de motor.
480sx
Car: 1996 Pearl White 240sx
nissanfanatic wrote: It would work if you maxxed the injectors at all times. Buy an AVC-R and adjust boost based on RPM using a 50trim so that your car makes ~260whp at all RPM ranges under WOT. And don't ever lift.
Lol makes for a stupid PITA drag car, thats... Not fast.....
2chuki4u
Car: 1993 Nissan 240sx
what are your safc settings?
neverlift
do not bump year old threads because you wont search....
