JDRosenberg07 wrote:After a couple hours, and i pretty good sunburn... Heres the end result:
my dude, what size wheels are those? What tire profile? Somehow, they actually look worse than the stock wheels/tires regarding the 4x4 look...
you need a drop ASAP!
I ask about the size profile because, if those are 19" wheels, and you run 245/35/19 tires, then that's about .6" smaller in diamter than stock, thus increaseing the size of that gap between your tires and the wheel well
if those are 18" wheel, and you;re running 225/40 18, then you're about 1.3" smaller than stock, increasing the gap even further...
just curious as to why the gap looks so large, even larger than the stock gap
***EDIT***
I just checked you mod page, and just as I thought, you are running 225/45/18, better than 225/40/18, but still about .4" smaller in diamter than stock. Thus you just increased the gap from stock by about .2 inches... every bit counts when it comes to the fugly gap on our cars dfrom stock....
in any case, if you want to fill up the wheel well more, even after the drop, I would suggest ging with 245/45/18... this will give you better traction (wider tires) and fill up the wheel well more. Of course this would probably be after you wear down these tires, but still, it asthetically, it would be more pleasing to the eyes!
