Sleeper s13 »
https://forums.nicoclub.com/sleeper-s13-u4428.html
Fri Jul 18, 2003 7:06 am
on the strut the sterring nuckle mount has two bolt holes. the bottom is exactly the size of the bolts themselves and the top one is slighty more oval horizontaly but only by about 2-4mm. I have thought that perhaps even that small amount could cause a visible change in camber but a guy that i work with that used to be a mechanic and the manager at auto zone both said that whenever you pull the front struts you need to do a front wheel alighnment. i was just wondering why it would change and how a front wheel alighnment could correct the camber?
