sorry, man...i was just asking about the thermostatic sandwich adaptor plate for the oil cooler. i wanted to know if it was a good investement or not, you know, just to get the engine to operating temperature sooner. thanks. which one are you using? i was looking at the inexpensive perma-cool kit.float_6969 wrote:Could you please type that a little more coherently? It's kind of hard to understand.
As for the oil cooler, I'm using one and it seems to work OK.
are you refering to the sadistic method of removing oil filters? or just that because the filter is remote located and the system is closed that it won't leak when stabbed?float_6969 wrote:Hey, did you ever verify that if you stabbed a hole in the filter that the oil would drain out and not leak all over?
if you're refering to the pics, i'm not going to do that again...ch187 wrote:im not really familiar with the whole blow-by system but dont they need vacuum to function and not breather filters? i guess i never understood that
He is referring to the fact that the filter is upside down in my setup. You stab a hole in the top of the filter so that it drains the oil in it (breaks the vacuum) so that when you take it off, there is a not a filters worth of oil that spills out. This is a major problem if you run a larger filter than stock (mine is like 2.5-3X bigger than the stock filter).fitch9014 wrote:are you refering to the sadistic method of removing oil filters? or just that because the filter is remote located and the system is closed that it won't leak when stabbed?
