JUst Want to Know???
outtacontrol240
just wondering im missing the ficd or the acc thing on the intake.....would that make something wrong with my ca18 cause when i got it didn't have that on there......somebody told me you can block that port off....YEs or NO? cause i got everything done just that little thing there...
well if you have a spare hit me up thx
[email protected]
Modified by outtacontrol240 at 11:37 PM 3/6/2006
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
The valves on the plenum do three things.
1. Sets base idle by bleeding a constant amount of air around the throttle butterfly. It's a 10mm bolt-head adjuster.2. long valve = FICD = Idle speed rise valve for when A/C is on.3. short fat valve = AAC = ECU controlled idle speed control to prevent stalling.
You can block them off, and adjust the throttle butterfly open a little to set the idle too.
If you live in a climate where the temperature is fairly constant, you can remove these valves and still use the factory ECU. Otherwise you will probably have to go aftermarket.
Hope this helps.
I don't use these valves with my Autronic SMC. But on a factory Computer, it's better to keep them.
gore
Car: 93 240SX hatch (ca18det)
yeah I controlled my idle through the throttle by, works fine. ran it at about 1000 vs 800 stock idle but it worked great
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
same here no AAC,FCID, or air regulator, just set the idle at 1100rpm and its fine.
outtacontrol240
thanks guys i appreciated it........
