240_s14 »
https://forums.nicoclub.com/240-s14-u702.html
Fri Sep 27, 2002 4:25 am
Ok, also here is another way to look at it. Here is the HUGE problem I see. Yes yes, the timing chain is metal, but what about the other internals running in unison with it such as the timing chain gears, rails, and most importantly the timing chain tensioner. All of them are PLASTIC!!. If the tensioner fails on the timing chain, the chain can cut into the plastic gears and boom, there goes all of your valves.
