Just swapped out an '02 VK45DE, and installed a '03 into my Q45. Won't Start.
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
HollywoodJackson
Car: 2004 Infiniti G35
1990 Nissan 240SX Hatchback
1990 Nissan 240SX Coupe
Greetings,
I just installed a 100,000 mile '03 VK45 into my '02 Q45. All the plugs on the harness appear to be plugged in right, except for a few.
  • O2 sensors before the cats, are not plugged in
  • O2 sensors after the cats, are not plugged in
  • The coolant temperature sensor in the back of the block, is not plugged in. Also, the '03's sensor is a different setup. The '02's harness seems short by about an inch. Maybe it should be rerouted?
I also took the fuel rail off my "02, as the '03 was laid out differently. The car wouldn't start, but it seemed to backfire once every three of four cycles... Any ideas on where to start searching for starting issues?
All the best,
~HollywoodJackson~
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Maybe its the crank angle sensor? might be different flexplate from 02 to 03?
HollywoodJackson
Yellow4g63 wrote:
Sat Aug 17, 2019 12:53 am
Not sure. The flexplate should be exactly alike. It's bent slightly, and as others have pointed out, it's probably why there's no fuel/spark/ignition.
I'm hoping. It should be delivered tomorrow, and I hope to have it installed by Wednesday evening.
All the best,
HollywoodJackson
PalmerWMD
Car: 2004 350Z
Can you give us an update? :)
HollywoodJackson
It was the ring gear that is a part of the flywheel. When I took the engine out, it got bent. When I swapped in a new one, the car fired up.
All the best,
~HollywoodJackson~
PalmerWMD
Car: 2004 350Z
HollywoodJackson wrote:
Sat Apr 03, 2021 6:17 am
All the best,
~HollywoodJackson~
Great!
All's well that ends well!
Return to “VH45DE / VK45DE / VK56DE Forum”
