mkory »
https://forums.nicoclub.com/mkory-u17964.html
Mon Sep 25, 2006 6:27 pm
So I just swapped to an SR after my KA took a dump, and got it running tonight. Runs alright and idles decent, revs fine under no load.
Problem though... When I drive it, I feel like there's very little power. You know the feeling like you're rolling at idle with the clutch out and mash the gas? It feels like that all the time and I dunno why. I can hear the turbo spool and BOV blow off, but the whole time it feels like a motor does at only 1k rpms. There's just not any power.
I'm thinking it has to do with the turbo not spinning the greatest right now (the oil was pretty gunky and the turbo was almost impossible to spin with my hand, but it's broken free since and spins a little better right now), lotsa back-pressure because of this and also some intake resistance. Any input is welcomed.
Also, the stock boost pressure sensor and wastegate solenoid... Are these important? The wiring harness done by Wiring Specialites has plugs to these, and I hooked them up, but did not run any vacuum lines to either. They're just kind of... there.
Thanks.
