Just Swapped Dash in All is Good Except one thing.
NICO's official source for Nissan upholstery, carpet, headliners, and trim information!
danger69
Everything looks great. Now for some reason my brake light on my dash is on even though my ebrake is down. I put everything in where they are suppose to be. It took me 2 1/2hrs to get it all done. Thats because I've never done this before. Can anyone help?
BackIntoAnS13
Car: 92 s13 hatch
Check your brake fluid. The light stays on when you are running low. Hopefully thats all it is.
S13FASTBACKSR
Car: '92 Fastback SR powered
ya but since you were messing with the dash it only makes sense that you accidentally did something to the wire that controls that little brake light on your dash
danger69
I had time today to fiddle with it. I know its not the gauge cluster, because when I was pulling the e brake somehow the light went off. And I thought I fixed it but it came back again. A few people said its the e brake sensor. I tried to fiddle with that too but it didn't work. I did check the brake fluid it is a tad low but nothing too bad for the light to go off.
let5l1de
Car: 89 coupe w/ silvia aero, le mans sunset "do the 626 meet! DO IT!
danger69 wrote:I had time today to fiddle with it. I know its not the gauge cluster, because when I was pulling the e brake somehow the light went off. And I thought I fixed it but it came back again. A few people said its the e brake sensor. I tried to fiddle with that too but it didn't work. I did check the brake fluid it is a tad low but nothing too bad for the light to go off.
im wondering if the e-brake switch connector is not making proper contact (try slightly bending the tabs) or the switch is faulty... good luck
S13FASTBACKSR
would that connector be the same as the sensor he said he messed with already? if not then yes give that a try but if it is the same thing i think it might be a wire having to do with the e-brake that came loose somewhere when putting in the new dash that is making a connection every so often
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
Probably forgot to plug in the harness for the ebrake sensor when you pulled down the center console to get the dash out. Or perhaps, you damaged the wire somehow. Take a look there.
jonah blanks
Car: 1991 nissan 240sx se coupe
could you email me the instructions to do this please
Return to “Interiors”
