Just swaped in a RB20det (hell of an experiance) and have a transmission question.
240sxRAOR
Car: Nissan 240sx Convertable 1992
It is the loadest trany I've heard with winding gear noise. Is that a bad sign? We changed the fluid which seemed fine when it came out. Maybe the guy had strait cut gears in it but I'm not that lucky.
Cjmartz2k
Car: Hunting for a '89 GTR now
No, it's not supposed to be like that if that's what you are asking. Probably a worn bearing. Get a new transmission.
240sxRAOR
Doesnt sound like a bearing but first gear shouldnt sound like reverse. Getting a new trany would be a horrid pain since we just swaped this motor in. Other than the noise it seems fine.
zmannz
Car: 89 s13 coupe- track car
92 s13 coupe- dd
Run it til it breaks then. I'm waiting on mine to go but I have a 25 trans to swap in.
sean@z1
Car: 1993 240sx
i can get you a new RB25DET transmission from Nissan for 1600 series 2 transmission. After you blow the first one up you can always upgrade.
Modified by sean@z1 at 10:59 AM 9/30/2009
240sxRAOR
I'm thinking of runing thicker gear oil like lucas and it only seems to wine in first gear.
sean@z1
Car: 1993 240sx
I use Redline 75W90 it is pretty good stuff
