Just some stuff
Cakesfab
New member here. Figured i'd post some of the more recent stuff i've made.
There are loads more pics of all these things in my photobucket. Feel free to go through it.http://s230.photobucket.com/albums/ee275/Miami240/
This is my car a few years ago. I lost all pictures of the setup but basically it was a bone stock, old KA from valve cover to oil pan with a custom turbo setup i threw together and tuned. It made 407whp at 14psi on pump gas and was eventually seeing 20psi on 110 octane before i took her down. I never got dyno numbers from that. It was only a street tune. I went 11.08@123 mph on pretty much stock everything and drag radials. Had her going 125.xx mph during my second trip to the track but unfortunately i botched one pass and didn't have enough heat in the tires the second. It could have definitely gone 10's.
Modified by Cakesfab at 6:56 AM 10/17/2008
Modified by Cakesfab at 7:30 AM 10/17/2008
Cakesfab
I had started to make new manifolds for it until i ran into a good deal on another motor. I ended up selling the stuff off to a friend of mine.
Cakesfab
I went ahead and started doing a VQTT setup for my own car.
Cakesfab
Changed up my buddy's setup and made him new stuff.
Cakesfab
Got bored of the VQTT setup and ditched it. Gave the shell to my gf and started putting together a kat setup for her.
Cakesfab
I have also done a bit of fabrication and standalone tuning on other cars such as my gf's 500hp srt4, a friend's honda sohc EF hatch, and another buddy's turbo k20 eg hatch and other 240's.
DevilMB3017
Wow.
Those are some nice pictures. Welcome to KA-T.
That's some pretty nice work there, but I just wonder what the spool time was like on those turbos being so far away from the block. I haven't seen too many people do it that way. But still a hell of a nice job.
NateDogg
Excellent work. Was Miami240 taken or did you piss off some people :-P
For those that haven't read "maximum boost" by corky bell, study these manifolds and you will have a great advantage.
Where did you get the intake manifold flange and plenum? How does the cast plenum compare with the fabricated piece?
Cakesfab
Someone took my damn name!
NateDogg
ahaha...maybe they figured they could get a free manifold for it
Did the fabricated intake plenum have flush-mount radiused entries or the velocity stacks like the cast plenum?
How much did that change the power output/curve?At what HP would you advise going to a short runner intake like that?
DevilMB3017
NateDogg wrote:For those that haven't read "maximum boost" by corky bell, study these manifolds and you will have a great advantage.
I have a copy of it somewhere...maybe on PDF. I should really start reading, huh?
Cakesfab
The new intake mani has the flush to the plenum backplate radiused stacks while my first intake mani had them raised off the floor. I have no idea how it changed the power curve considering i have never performed a controlled test. The only reason for using those RMR stacks is for convenience. I would much prefer a larger ID running with a small taper and a big, variable radius velocity stack sitting just slightly off the backplate but i haven't found the materials to do it with AND maintain durability. I also don't have the capabilities at this time to make my own.
I don't suggest a switch over to a short runner intake mani according to hp level. It should be more based off of your use and personal preference. Some people are anti rev. They like to keep rpm down and low end torque high while others prefer a much peakier/smoother powerband ad that's when i recommend a switch.
480sx
Car: 1996 Pearl White 240sx
Very rare that i see a custom intake manifold that i like. That first manifold that was on your old setup was very well designed.
The VQ setup is sick too.
Gotta love your turbo choice . What BW are you running on your new Ka-T?
So your mostly a drag guy? Or are these streetable?
Cakesfab
My buddy's new setup is a s372. My gf's new setup has a s366. I am a drag guy but street drag. I hate track only cars. Even though i might prefer a fully gutted/chopped car, i still like to keep it stick shift, steady smooth idle, non overheating, and overall good driveability.
Modified by Cakesfab at 10:36 AM 10/17/2008
kouki_hmongster
Car: Want 97 kouki
What welder were you using to weld? looks really nice, i plann on custom making my own turbo manifold. also is that red s13 coupe 240 the one on youtub "raymond" or something? you think you can make me a manifold?
Modified by kouki_hmongster at 11:03 AM 10/17/2008
Cakesfab
Yea, that's Ramon's car. I have a Miller Synchrowave 200.
neverlift
you my man are badass! no wonder ozi is moving back to miami....
vids or ban I dont mind if they are street runs
WDRacing
I agree 100%, especially on an over square motor.
Welcome to Nico, good to have an experienced fabricator around. I'm just a hack and slash guy myself. Mig and oxy/ace can do anything, not pretty, but it works My next big purchase would be a plasma cutter...I'd be in the shop for weeks at a time if I had one of those.
Think you could fab up a transmission adapter? KA to TH350/400?
WD
Cakesfab
I would love a plasma cutter as well but i'm afraid i'd end up with a death trap on wheels.
Glad to see another fabricator on here. Not sure on the trans adapter and definitely not for an auto.
WDRacing
DUDE...cmon.
A fellow drag racer should know an auto with a stall is faster in the 1320
Cakesfab
WDRacing wrote:DUDE...cmon.
Oh i know.... but there are two things i will never do to a car... make it track only or put an auto in it. I am all about actually driving my car. I see auto as a cheat for those that can't drive.
WDRacing
Yeah...a lot of people say that. My drag cars are also my daily's, track only is for pro's and people that race on a road course.
I grew up in Boston and enjoy the city...will be back eventually. Driving a manual in traffic blows goats my friend. I currently have a manual though, and I do enjoy it. The auto is so I can make my daily as fast as possible. Auto's launch better and, IMPO, nitrous works better with them as well. I'll be doing a roots style supercharger for my next project, so I won't have any lag issues but I'll have a max boost of about 15psi before the rpms eat the bearings inside the Eaton unit I'll be using. I can't afford a whipple or Kenne Bell unit... So I'll be using nitrous on the track.
What size tires are you running on the S14 in the first pic? I'm going to go with 275/60R15's on mine, with Summit 5 star alum specials
WD
WDRacing
DUDE........my eyes...!!!!!!!!!!!!!!!!!!!!!!!!!!
Cakesfab
WDRacing wrote:DUDE........my eyes...!!!!!!!!!!!!!!!!!!!!!!!!!!
That my friend is a good buddy of mine that drank a little too much and acutally posed for me in my gf's bra... biiiiiig mistake. I'll never let him live it down.
Cakesfab
WDRacing wrote:Yeah...a lot of people say that. My drag cars are also my daily's, track only is for pro's and people that race on a road course.
WD
In the first pic, those are 275/50-15 MT radials. The red s13 is on 275/60-15 MT radials and here is a pic of his 28"ers on my s14...
IMO, that is the perfect size tire for a drag s14 street car.
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
OMG!
WDRacing
Damn, those look like the same wheels I'm going to use. Are they Welds by chance? 8 or 10 inch? What spacing did you use? 28's it is!!!
I'm a huge fan if bigger is better
Cakesfab
Weld Prostars 15x8 with 5.5" BS
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
I reconized that the first pic from a vid on you tube running low 11s and a vid of you blowing out 3rd gear i believe racing a early gen rx7 with a v8 swap. Those are some sweet setups. Cant wait to see the finished product on this one....i hope you finish it
ghx407
Car: 1993 240SX KA-T
Impressive work.
