SVTCOBRA wrote:Just my experience. Both Pathy's had sensors go bad including o2's and cam shaft pos.
I did not keep any of my cars much past 100K, probably never will, but yes, had fewer problems with my Fords. Now, I did love the Pathy's, Max, and 240SX.
However, now that my 05 is approaching the end of it's bumper to bumper, I'm pretty sure that I'll be getting an extended warranty based on the troubles that I've experienced with Nissan/Infiniti.I really didn't expect to be doing that!!! Since I never bought them with my Fords and didn't need them.
Note that I'm not bashing Nissan/Infiniti, I'm just very disappointed in their reliability!!! Oh, and you have to remember that the fact that my sedan was in the shop for 1 full month for the third time for the same thing is still very fresh in my mind.
Modified by SVTCOBRA at 11:47 PM 7/10/2009
Since March:
In 3/18/2009 Given a loaner.
Out 3/20/2009
In 4/13/2009 IPDM taken from another car due to not be able to get a loaner.
Out 4/13/2009
Would not start 4/14/2009 and then started.
Would not start 6/04/2009
In 6/05/2009
Out 6-17-2009
Now the real kicker - less than 8 hours of time charged to work on the car, car out of service 16 days with them being in possession for 15 days.
Twice during this sequence the car was damaged. One when they dented and scratched the trim plate around the shifter, the other when both front mud guards were damaged apparently by the tow truck. The first time was a scuffed front bumper which I polished out myself after waiting all day only to find some of the work under warrranty was not done and had to wait another hour for it to be completed after I refused to accept it.
It has failed to start (on the first try) twice since June 16th (last time July 1st) with no codes tossed. The last time it may have been the key not recognized with the key symbol showing even after it started until the car was put in gear. I don't know this since another issue that has cropped up during these times was the steering lock not locking, once tossing a code which showed up on the second time in the shop on April 13th when the IPDM was replaced. Personally I think I am looking at a cable issue (I have a good reason to believe this, not simply a guess) which is being danced around. I don't believe the IPDM had anything to do with any of this (with the exception of cable involvement) and the BCM may in fact had bit the dust.
Here is one issue. Would I drive this car to California from Washington like it is. The answer is no. If this situation had happen in California with the same issues getting it fixed, I would be out of a job for unexcused absence. Would I drive my 300 m to California? Good question. It has never let me down (will probably die tomorrow) and I am fairly sure it would not have any issues even though it is starting to pick up some miles and needs at least some love in the way of plugs if nothing else. I am at about 149,750 on its odometer. Total time in the shop including a timing belt replacement with waterpump, brakes with suspension part replacement, since I purchased at 62k miles - 3 days. 1 day of that was for bad install on the radiator drain plug which I understand is harder than it sounds. None of this was warranty work. Loaner car provided from rental company for the timing belt replacement due to the leaking drain plug.
So what is wrong with this picture?
Perry
