JUST SOME QUESTIONS?
sly240
Car: 93 240sx
Well I’ll start off by saying that my spelling is just plain bad.
Anyway I’ll start with my engine I have 2 problems. 1) I believe I am burning oil I have excessive blue smoke coming out the exhaust and my BOV is spitting out some oil to. so I think it is the cheap eBay turbo I’m running :facepalm: ( I know I know but I will be getting it replaced) but my compression in all cylinders is also low(like 135) so I think it is a combo worn rings and crap turbo. Any thoughts on this? 2) It will start to miss when I get on it with someone else in the car. I think it is the added weight because when I am by myself id doesn’t do it or at least not as bad. I have an inductive timing light (the kind that has to be hooked up to the #1 spark plug wire) but my sr is a coil over plug design so does anyone know if I can make this timing light work or how I can check the timing on my engine. I guess I should say that I think it is the timing because I replaced the crank angle sensor. Also does anyone know the correct timing for a redtop sr20 is it 15Deg BTDC?
Now I ordered a complete z32 5 lug and brake setup so I am looking for some wheels. I wanted the volk TW37 SL (who doesn’t right) but they are a little pricey and seeing as how my budget is not that high and I’m sure I will want wider rims in the future I was wondering if anyone new some quality wheels for a decent price? I have been looking at gram lights but wanted to get some opinions first. I’m looking for some 17's at least 9" wide I would kind of like to do a staggered with some 10" wide wheels in the back. I’m more going for performance not looks so I don’t want some chrome bling that weighs 50 lbs something light with good fitment on a stock body is what I’m going for. If I can't find some quality wheels in my budget I’m thinking of going with the MB battles anyone have anything to say on these?
Well that’s all I got thanks for any help. I have been searching around but can’t seem to find just what I’m looking for. So if anyone can shed some light on any of this that would be great thanks.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
can't help you with the sr, but only n/a z32 rear hubs will work. if you bought turbo hubs, you have useless (to you) parts. if you got n/a hubs, you still need to source some front hubs, i'd suggest s14.
if you can't afford the volks, you can't afford the gram lights. once you go 5 lug, rock some z32 turbo wheels for a little while until you can afford what you really want.
sly240
Car: 93 240sx
I got the n/a hubs and still need to get the fronts. i was going to go with the Ichiba front hubs any reason not to go with them? and do the z wheels have good fitment and any kind of price on these?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Ichiba are what you want, I'd avoid the cheaper ones as they dont use OEM bearing where Ichiba do. Z33/34 wheels fit good for cheap, but there is alot out there.
