Just shoot me
DrewQ45
Car: 1990 Infiniti Q45
just shoot me 90Q, 170K, Atlanta
Hi folks,
It’s been a while since I visited here. Family and multiple jobs keep me too busy nowadays but I’m slowly working myself back in. Hope everyone’s doing okay and the Nissan / Infinitis are still humming along. Boy things have changed around here.
Lately my main mode of transportation has been a Dodge truck while the Q takes a rest in the garage. I drive her on weekends though. Of course, ya’ll know this leading up to some sort of dilemma so here it is.
While the Q sat, I decided to fix a few things that were bugging me. I changed out the AC Display which was blank and also not keeping the temperature right. I found a post where someone had flexed the IC card rendering the display viewable again. I changed my display to a used display (freebie) which also had the readout problem (but kept the temp right) and flexing the board brought it back as stated. Many thanks to whoever that was.
A few years ago, I had changed out the speedometer on my cluster. The new speedo worked but along the way, something happened to my digital odometer display and I didn’t realize this until after putting everything back together. Well, I drove it like that until now.
I ordered new odo bulbs (yes, it’s digital but uses bulbs at the back) from Scottsdale, installed them in the display hoping this might fix it… then I made my dumb error. The car had been sitting in the sun and I had it running with the AC on as I tried to put back in the cluster. (Yes, just shoot me cause I do know better). It was my intention to disconnect the battery before reassembly but I completely forgot. I guess the AC was feeling too good. While twisting and turning the cluster to get it in, I think a metal cover at the back of it shorted out on the exposed ignition wiring on the steering column. I heard nothing, smelled nothing but noticed that the AC had turned off suddenly which is when it clicked in my thick head that I had the car running.
Now the AC display unit does not light up or work at all, the car is not charging from the alternator, none of the gauges work and God knows what else. The console and cluster lights are working when I turn on the headlights. The car starts and runs but I don’t keep it on long since the alternator is not charging. This is a new dealer alternator that I installed over the summer. I’ve checked fuses etc. but found nothing. I think the power steering stopped working too. I’m hoping I may just need to change a relay/s but I’m not sure. Any help would be appreciated. Cuss me if you wish but only if you can help
My next option will be to flatbed it to the dealer if no solution is found (now the tears start).
…Drew…
Forgive me for posting in multiple forums. I'm trying to get maximum exposure here.
911/Q45
1996 Porsche Turbo
You've groveled enough so I won't dump on you anymore. Take it to T3 there in Atlanta and let Dennis put it back together for you. He'll dump on you some more, but it will get fixed right and you won't pay more than you should.
Jberger
Bummer Drew, Maybe Dennis will loan you a magic wand or something. Joe over at Falcon Towing can help you get your ride to T3.
Sorry about the problems, but glad to know you're still around. Welcome Back.
