Just replaced my motor mounts, car still shakes bad on freeway
0ptimus prime
Alright so here's the deal. I just bought a 240 off some guy and he told me that it shook REALLY bad on the freeway because the motor mounts were shot. All was fine because i figured i'd upgrade motor mounts for an SR swap anyway.
The problem is that at around 70+ the car starts shaking VERY dangerously to the point where i absolutely cannot go any faster as the car will shake to death.
Fast forward to today. I changed all three mounts (motor and transmission) and the car STILL shakes rediculously on the freeway. An observation that my buddy and i made was: With the car on all four jackstands, we put the car in gear and took it to 5k rpms through every gear. By the time we hit third gear, both rear wheels were shaking to all hell even while the car is off the ground. What could be causing the rear wheels to shake like this? Any input would help, thanx!
SeVa-S13
Car: '05 GTO 6spd
Check bushings in the subframe and driveshaft. They the stock wheels?
0ptimus prime
nah bro, they're on older datsun wheels. The offset isn't very low at all; probably close to FWD offsets. But the rims don't seem to be bent. As for as i can tell, the tires don't seem to have any bumps or anything either. I don't know what could cause both tires to shake to all hell in mid air. I'll check out the bushings and maybe get a video clip of how it looks.
Hijacker
Car: '92 240sx Convertible
'94 F-150
get your wheels rebalanced
SeVa-S13
Car: '05 GTO 6spd
Don't know much about the Datsun whee;s but are they hubcentric?
sensibleS13driver
I think hubcentric rings make no difference, just speaking from experience, but any tire place will tell you you need them. I'd get the tires rebalanced 90% of the time thats the source of freeway vibration.
SeVa-S13
Car: '05 GTO 6spd
It really depends on the car. I've worked in the beusiness for qite a while and know that it can make a huge difference...but rarely, if ever, in the rear.
FattyMcBaggins
Car: 1990 Nissan 240SX
But how would the tires make his car shake when he said that the rear end shook violently even while it was on jack stands?
574-240sx
Car: Nissans, Toyotas, Subaru
tenkawa_akito wrote:get your wheels rebalanced
agree. Also old Datsun wheels should be fine on a 240.
TheOne
Car: 93 240sx FB
get the wheels balanced, that happened to a mitsu eclipse i used to own, the tires were not balanced so the car would shake after goin above 60mph.
Red coupe
Car: 92 Nissan 240sx Coupe
FattyMcBaggins wrote:But how would the tires make his car shake when he said that the rear end shook violently even while it was on jack stands?
when things spin really fast imbalances make them shake...If you say the problem seems to be in the rear you could try the ol tire swap and change the fronts for the back, and visa versa, that way you can tell if its an alignment/suspension thing, or a tire/wheel thing
as far as hub centric rings go I don't think they would cause shaking would they? from what we learned in suspension class the deal with them was to properly transmit the load of the vehicle from the rim directly to the hub, so that the lugs simply hold the tire on, but do not support the weight of the vehicle...
SeVa-S13
Car: '05 GTO 6spd
Nonhubcentric wheels are the most common source of shaking at highway speed for aftermarket wheels. If the the center bore and hub don't fit right, then there's play in the wheel's fitment and while you can bolt it down and it won't come off, you'll never get it exactly centered: it'll be like rolling on an egg in theory.
