First off i'll reference the original how-to for this:
http://forums.altimas.org/zerothread?id=340563
First thing i did was get a flathead screwdriver and a semi thick hand towel to wrap it around, then i started on the top right corner (where its thinnest) just as described in the original thread.
http://img413.imageshack.us/im...4.jpgh ... im...3.jpg
Be gentle with initial "digs" into the gap between the chrome and the grill as a the screwdriver head will cut through the towel and scratch the paint (very small scratches but still avoidable).
http://img370.imageshack.us/im...6.jpgh ... im...2.jpg
Once you get this top part loose I recommend using your fingers to pop out the brackets. You can wedge the screwdriver in the bottom-middle of the mustache (where its thickest) to loosen it up a bit if your fingers cant grab on initially. Your fingers will provide you better control and more power to remove the clips safely and you wont damage the paint.
Just repeat on the other side and your good-to-go!
http://img413.imageshack.us/im...5.jpg
