Just rebuilt engine and cant get car to start
jrankins05
Car: 91' nissan 240sx
I have a 91 nissan 24osx manuel 5spd, Its been sitting in my garage for 4 years and last week i rebuilt the engine and can not get the car to start, i put chemtool b12 in with the gas to clean fue lines and injectors, and new spark plugs and wires but cant seem to figure out why the car wont start, and need some help
P_856
Car: s13
did you check the grounds are you getting power? is there gas? and spark? does it crank?
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
if it has been sitting for 4 years your gas is probably no good and you can probably trash that fuel filter too.
jrankins05
Sorry i should have mentioned i dropped the gas tank and cleaned it out and but new fuel in witht the treatment, im gonna disconnect the filter and try and start it and see if i get gas flow, and getting new filter today.
maniacman9558
Car: 93 240sx n/a KADE (for now! =P)
05 ninja zx10r
if you do all that and you have gas and spark and it cranks over and all that try turning the dizzy. had the same problem with mine and took acouple trys to get it right be got it to fire up after like 3 trys
240dx
Car: '97 Nissan 240SX LE
check your cam timing man. most engine that cannot start after a rebuild it ends up being their cam timing
