Just ran Nitrous. *Summary - Weee!!!
Gladius
I finally got the nitrous hooked up after a week of waiting. I have a NX Stage 1 kit. Picked it up for a great deal $475.00 at suprastore.com.
The reason I had to wait a week was I broke off the adapter fitting that goes inbetween the Nitrous feed line to the shark nozzle. BEWARE, those things are weak. Use caution when tightening. I was able to drill the adaptor out of the nozzle and "easy-out" the rest. So I didn't have to buy a whole new nozzle. Thank the Lord.
- Moving Along -
Current setup includes:1989 240sx with SR20DET (with horrible paint, a real piece of ****)GT25R Turbo3in dp and exhaustTial 38mm wastgateJWT Reprogram72lbs injectorsZ32 mafCustom Intercooler piping with Greddy I/cGreddy Profec B Spec IIKoyo Aluminum Radiator2-12" Electric FansKyb Agx's with Ground Control SpringsEnergy Suspension Master Bushing KitVarious GaugesOh yeah almost forgot Nx Stage 1 Nitrous... heheAll this with a peg leg. :eek:
- Impressions on nitrous - 2nd gear - Very scary above 4000rpm3rd - Stout pull, can really feel the G's4th - Still pulling and approching 2x's the speed limit.5th - I dont spray, too much load on engine, dont want to blow it.
The kit was simple to install and looks to be of nice quality (except that damn fitting). I will report my 50shot jets results in the next couple days. Tee hee hee.. ;)
silkk
Car: 94 B13
89 S13
07 S2000
nice!
make sure to post pictures :)
Gladius
I knew I forgot something.
Dori Dori
Car: Cars of course
Nitrous and boost...it's a beautiful thing.
I'm surprised more people here don't run it.
mackdaddy240
Car: High performance with a clean look.
most people are scared But I do understand why, if your cars not running right/LEAN and you shoot a lil nitrous into it you're going to have to rebuild your bottom end. Most people cant do it themselves and it cost a lot of $$$ to pay somebody. But I love it
Gladius
Installing it was easy, just follow the instructions.
electricproblem
any pics??? was it a wet or dry kit?
Gladius
Here's a few pics. Check em out.. my car is really dirty and kinda ghetto right now.
http://pg.photos.yahoo.com/ph/...hotos
Modified by Gladius at 9:31 PM 10/27/2004
electricproblem
cant see them.......
nismostate
Car: all sorts of motorsports
mackdaddy240 wrote:most people are scared But I do understand why, if your cars not running right/LEAN and you shoot a lil nitrous into it you're going to have to rebuild your bottom end. Most people cant do it themselves and it cost a lot of $$$ to pay somebody. But I love it
that and im using my car for turns!
Gladius
OK, now it works.
SRdave240
Nice, I'd like to run a small shot on my GTiR turbo someday. Did you make any timing adjustments?Also, isn;t the bottle supposed to be titled down?
Gladius
Nah, I left timing as is. The bottle is supposed to be like that, because there is a small siphon tube that runs from the valve to the bottom of the bottle.
kota2240
Car: 92 Nissan Coupe W/ CA18ddet
what do you guys think about spraying the intercooler? safer?
Gladius
Running a wet kit I wouldn't recommend it. I dont think you want to inject fuel into you intercooler.
Now if its a dry kit, more power to ya. But then again dry kits aren't really safe for our fuel set ups. Unless you have something to compensate for the added nitrous.
Oh yeah, spray nitrous on your intercooler to chill it.
kota2240
chilling the intercooler, do you have to worry about timimng or fuel upgrade
got2b240
Car: 91' RPS13 = GT28R, 525cc, Z32 Mafs & SAFC, Blitz EXST & FMIC, Silvia VLSD
nope you wouldnt have to retard timing, your motor will just recieve lower air temperatures, densining the air and producing more hp due to a better burning mix. Your motor actually does not take in any N20 because its getting sprayed along the outside to cool it off. I have a friend that uses this setup on his single turbo supra producing great results.
So timing and fuel may remain the same, if anything you may advance timng a degree or two more safely because the cooler the mixture the less of a chance of detonation
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
so does using the N2O to cool your IC instead of injecting it into your engine produce the same type of power in a safer manner?
DriftS14
PantherRacer wrote:so does using the N2O to cool your IC instead of injecting it into your engine produce the same type of power in a safer manner?
Nope
