Just put 20's on
rnenniiv
Car: 2011 Nissan Rogue S
This pic is kind of bad I will post better ones soon. So how do you think they look? Is there any way to override the low pressure sensor without installing them in the new rims?
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
Looks great.
Might be a stupid question, but is there any way you could put more rubber on the tires itself. As in get bigger tires, yet they still fit on the rims. :wavey:
harryg
I think they look great too.
You can go with a "thicker" tire but that will most likely throw off the speedometer, you want to remain within the OEM tires diameter
philipa_240sx
rnenniiv wrote:Is there any way to override the low pressure sensor without installing them in the new rims?
No. There is no way to bypass the TPMS system (ie. by pulling fuses, disconnecting wires, etc).
The TPMS sensors must be installed in a wheel and that wheel must rotate for the sensors to activate. I've seen a trick where the sensors were simply put inside a sealed and pressurized can then placed inside the vehicle. That won't work as the TPMS sensor is only activated during motion in order to extend battery life.
NYMMA
Car: 2011 Nissan Rogue SV
what size tires are on those 20's?
TaiLuu
Car: 2009 Nissan Murano LE AWD
2011 Nissan Rogue SV AWD
2014 Nissan Pathfinder Platinum
harryg wrote:I think they look great too.
It wouldn't Throw off Speedo.
The Sensor for the Speedo is at the transmission.
But He would get more grip during winter.
Return to “Rogue Forum”
