Now I'm coming from a ka24det, so i have a few questions about the bottom end of the sr20.
How much hp/tq should my bottom end hold if I put new rings, bearing set, and a full gasket set? the hks metal headgaskets only go with 88 bore and 87 bore..isn't the sr20 a stock 86 bore? So what good metal headgasket's are out there for the stock bore and are somewhat thick?
I plan on putting new cams, some hks cam gears, port and polish on the head, all the good stuff up north, and then I'm thinking sticking with the bottom mount and getting a gt3071r and trying to push around 350/400whp...can the sr20's bottom end and such handle that?
Thanks for answering my questions!
