mazikowski »
https://forums.nicoclub.com/mazikowski-u67058.html
Tue May 12, 2009 7:22 pm
Yeah, it's the FICD (Fast Idle Control Device) and it gives the engine more air to bump up the idle when you turn on the AC to combat the parasitic loss presented by the compressor being engaged. As stated, if you don't plan on using AC you can just leave it.
It does unscrew, at the end closest to the IACV (Idle Air Control Valve) it has flats that you can put an open end wrench around and turn it right out.
EDIT: Welcome to the love-hate world of CA ownership! It may give you some problems but it's all worth it, that little engine will make you really happy!
