Thanks for the quick replies guys!
When I first brought the vehicle home, as I was driving the entire instrument cluster actually burnt out. I popped the hood and replaced the TAIL fuse as soon as I got home. Once I did that the cluster was back in action, everything else I mentioned stayed off.
I'll go over some fuses again this morning and see if anything else is burnt out. I'm going to download the FSM and OM from the website and will have a look over them today as well.
As for the white cluster. I was looking to replace mine with the one in this HOW-To located here:
how-to-replace-instrument-cluster-lamps-t461756.html This one actually has white faces where mine are black. It also has a nicer 4WD illumination, though I was reading up more last night and found out that those particular clusters only work with Automatics and not Manuals? Is this true?
Thanks for clarifying which lights up and which doesn't. I've made a list of bulbs to replace in case everything is burnt out and it's not just a fuse.
The first thing I was worried about was the strut housing corrosion recall. This vehicle was originally from BC. It's in really good condition for having 300kms on it and not much body rust compared to the other Pathfinders I looked at in my price range. The front wheel wells appear to be in excellent condition as well with not much rust. I can provide photos if needed.
I have done oil and filter, power steering, coolant and the engine air filter so far. Transmission, Diffs, Brake fluid and Clutch will be done hopefully before the end of the month. I'll check the cabin air filter sometime this week.
Why would the accelerator and cruise throttle wires need to be adjusted if you don't mind me asking? Do they loosen over time?
This vehicle was equipped with stock fogs at one point. I'm not sure what happened to them as the wiring and mounts are still there. The turn signal stalk has the foglight switch also, so all I need is a pair to splice in and I'll be good to go!
Thanks for the TSB warning as well. I'll consider this before making a purchase in the future.
Thanks again! I'll go over some of the stuff today and see if I can locate the problem. It gets dark pretty early up here, so it would be nice to have complete illumination inside
