rxm6 wrote:Hey all, just picked up a 99 t and I had a couple of questions.
1) The car has 126k on it and the engine is ultra clean. Can I use full synthetic in the vh41 or will i get buildup? I had a vq30 that I used full synthetic in and it was great, but it caused a lot of grimy buildup around the gaskets as i kept using it (used full synth for 40k, which is four oil changes ). It could have been from age (it was approaching 180k), but I'm curious if anyone here has used full synthetic in these engines for any length of time and the engine stayed clean.
2) Will 18x8 +30 and 18x8.5 +33 fit without looking silly?
3) Will a steering wheel from an 01 fit on a 99? I really like the look of the wood on the wheel of the 01.
1.) If course a VH41DE does fine on synthetic. Never heard of a grimy build up, but 10K is way too long between changes. Do you think your crankcase gets any less contaminated on synthetic?
2.) Yes they will fit. Most important is weight, strength and hubcentricity. Of course all is nor naught if you cheap out on the tires or the suspension and brakes aren't in A-1 condition.
3.) Sure, but how do you know when you should wear driving gloves or not?
Welcome to NICO.
Modified by maxnix at 8:26 AM 5/1/2009
