what? 73 came with SU's granted they were the hackjob imitation SU's with lots fo emissions garbage added on but still SU's and definitely not webbers, even the DGV's would be an improvement over the flat top SU'smikeith wrote:Newly rebuilt SU carbs from a ’72 were installed in place of the Webers
evildky wrote:what? 73 came with SU's granted they were the hackjob imitation SU's with lots fo emissions garbage added on but still SU's and definitely not webbers, even the DGV's would be an improvement over the flat top SU's
and the sunbelt engine is a nice piece, shame to pluck it but it certainly can't compare with a turbo V8
and yes it always pays to spend mroe ont he fornt end and start with a better project, glad you found a good one, and selling off that engine will help offset the cost of your build
just noticed this part, sorry it's not possible, I'm running 315's with coil overs and they stick out about 4" from my flared fenders, more like 5 fomr stock, I could get maybe another .5 of backspacing but that would be very close and most likely rubbing the strut housingmikeith wrote:modified rear suspension to handle 315/35-17's w/o going outside stock fenders
whats the specs on scotty's gnz? i'm not too worried about launching i'm more worried about it breaking loose from a roll... after seeing how bad darius' car used to do from a roll i just dont want those problems. i plan on running as sticky of a street tire as i can find and stuff i just dont see it doing much without allowing for more of a contact patch... it also seems like using a c4 rear would cost alot more and take alot more fab work than what i am wanting to doevildky wrote:I had read that thread, kinda seems like you are reinventing the wheel, converting a a narrowed C4 IRS with tubs would be the better option IMHO, not sure what size tire scotty was runnign his GNZ but it was a lot and it hooked and it ran low 10's, actually there si a guy with a 2JZ running low 10's on street tires on stock suspension with dot tires, it's all about setting it up for the lauch, wider tires doe not equat better traction, mine doesn't hook worth a dang in a straight line, but it'll turn with the best of them
cool thanksevildky wrote:I was dismanteling my IRS the other day and one problem with your strut and tower relocation is you get into the companion flage for the halfshafts, so the coil overs, get an 8 wheel and LCA's camber plates and good struts and coil overs
