adl16v »
https://forums.nicoclub.com/adl16v-u46301.html
Tue May 05, 2009 6:29 pm
Hi I just picked up a 89 240 sx with the original ka24e engine for a fixer upper It seems to have some issues some of you can maybe help me with. When I picked it up it had some hesitation problems but i just changed the plugs, wires, cap, rotor and fuel filter and seemed to fix that.
It idles at about 1300 once its warmed up which seems pretty high once in a while it idles up and down from 1200 to 1400.
When im accelerating the shifter seems to wobble around quite a bit idk it thats normal? but im going to check on all the mounts when I raise it up tomorrow.
It is a manual transmission and when I put it in reverse the idle drops down from the normal 1300rpm idle to about 800rpm any reasons for that? Also idk if it is a cluster malfunction but when I am in neutral sitting in my driveway revving the engine the mph gauge goes up and down along with the tach.
When I turn on the headlights one one light pops up and a good 30-sec to a minute later the other light pops up that one serious lazy eye. and suggestions? maybe wiring issue?
Thanks
