datsunboy »
https://forums.nicoclub.com/datsunboy-u15035.html
Fri May 19, 2006 12:38 am
you know......theres a MUCH better way to reverse the front crossmember than to cut the middle section out!
what you do, is take out the pins the control arms bolt on to, and you'll notice that they are tappered.so what you do, is cut that tapered tube out, turn it around......and weld it back in.make sure you make SURE, that it is welded back in, in the same place it was in before, or you'll screw up you suspension geometry.then you just bolt the crossmember back into the car backwards ( you'll need to slot a 2 of the mounting holes a little ).
Thats the way most people do it in Australia and NZ......you americans do some strange things.....lol
