Calvin »
https://forums.nicoclub.com/calvin-u5675.html
Sat Aug 30, 2003 9:48 am
Personally, I'd only use drain cleaner as a last resort, because you'd be putting it in the same duct that your air blows through. I wouldn't want to breath that stuff, even in trace amounts. Its not exactly spring fresh =)
Basically, the A/C evaporator under the dash is encased in a plastic air duct. Moisture from the air forms condensation on the cold metal of the evaporator, and eventually starts dripping, creating a puddle on the bottom of the plastic air duct. For this reason, the plastic air duct has a drain. This drain is only a couple inches long and sticks straight though the firewall, so the water can drip on the pavement.
There is actually a little rubber extension piece on the end of the hard plastic drain tube. If you lift the hood and look at the firewall on the passenger side, and you should see this rubber drain extension. It looks like a rubber hose that is only a few inches long and is bent to point toward the ground. Make sure the rubber hose is there, because without it, the hard plastic drain might not be long enough to extend past the firewall. A missing rubber extension could itself be the cause of wet carpet.
Anyway, since the hard plastic part of the drain is only a couple inches long, it should be easy to clean by hand with a few pipe cleaners from the craft store or something... be creative. You might have to remove the rubber hose thingie from the firewall to get good access to the actual plastic drain tube. (Be warned, if memory serves, the rubber thingie is a nuisance to get back on)
