First of all, welcome to the (Dark Side) nissan family and welcome to NICO as well. Now let's get to your question: Why do you want to put cams in an engine that you're not familiar with? And seeing that you are already wanting go-fast goodies on a wallet budget tells me that you are not ready to get down and dirty with the go really-fast gang. My suggestion is to learn about the machine you have and make key decisions as your needs require you to. Don't be afraid to ask questions, but please don't be lazy enough that you won't take advantage of the search function as well. Oh yeah, you don't need cams just yet .s1390 wrote:I just picked up a 1990 240 with a silvia conversion the guy I bought it off of is a friend of mine and took very good care of the car and the motor was rebuilt recently. I was just curious if anybody could point me in the right direction for cams thats also easy on the wallet Ive done some research but Im just gettin into nissan from honda so if anybody could throw me some pointers it would be much appreciated.
If you are truly running 18psi, as stated before, the engine is in suicide mode. As stated, you got a lot to learn about nissan products and you should take the time to venture this forum's vast about amount scenarios to see where you want to be and what it takes. There are many on this forum that have failed and a very small amount that have successful installs, so becareful at what advice you take heed to when given to you. As for the injectors you say you ordered, do you know what your ecu is tuned for? Be very careful my friend or you will hit a wall of disappointment "quickly".s1390 wrote:i just ordered the fuel pump and injectors can i get by without swappin the turbo for now
That won't spare his motor sudden death if he has no device to adjust parameters.streetsound wrote:I would recomend that you get a wideband air/fule meter to have control on the air/fule ratio.
