Just ordered some FN01RC from SPL
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
Many people recomended both the wheels and SPL, so I went for it. 17x7 +35 Hyper Black for my black s13 coupe. Figured HB was a good compromise between Silver and Black. Some Kumho MX in 225/45/17 will be ordered soon, then i need to get some brakes to fill these massive things and some suspension to take advanage of my new found stickiness.
Modified by IveBeenBad at 4:20 PM 2/7/2006
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Neato...
-Dan
SeVa-S13
Car: '05 GTO 6spd
Now I'm not one for wheels sticking out past fenders but you probably could, and should have gone with a wider wheel. Just an opinion...
240sxjeff
Car: nissan 240sx zenki version
^Ditto, you should have gone with the 9 inch wide FN's
IveBeenBad
I know a lot of people have a wider is better philosophy, but from a cost standpoint as well as my future plans for the car, 17x7 works out better. BTW I only order 2 wheels so I could see if I want to go with an 8" in the rear instead of a seven.
chmercer
you do. haha
Badfish
Car: 93 Nissan 240SX w/ black top SR20
Hey mercer, what are you doing posting pics of your car on Something Awful?
I digress,I bought my 17x7's a couple years ago. I didn't want to stagger them. I cant remember what was available at the time but 4 lug sizes lug sucks. Ive got some 215/45/17's st115's on them.
If I had known at the time I couldve put 17x8 +35 on all around with the same size tire I probably would have went with that. They're still good wheels, though aat some point Im going to 5 lug.
PencilShavings
Car: '91 240 hatch
so will FN01RC 17x8's (+35??) fit on all corners clearing 300zx front brakes?
also, it wont stick out passed the fenders will it?
any pics of this setup???
Badfish
PencilShavings wrote:so will FN01RC 17x8's (+35??) fit on all corners clearing 300zx front brakes?
SR_Smith's old setup. Anything wider than the 215's will rub coilovers. zerothread?id=95740 zer...age=2
Not 100% positive these will clear Z brakes. Anthony (Structure240sx) had them but you might wanna check to make sure.
zerothread?id=83418(He says it wont clear coils cause at the time he was running 235/45/17's up front)
Zion8561
Car: 92 Nissan S13 Fastback
I just ordered the same wheels....from the same place yesterday. 17x7 all the way around, hyperblack. The only bad thing about the FN's is everyone has em. Also got the G-force sport tires for now.
I didnt want to go with the staggered setup with wider wheels on the rear because it would increase understeer. I might change to 17x8 after I add some power and get a LSD.
PencilShavings
Car: '91 240 hatch
Thanks for the links...Now I'm confused though, Structure said the 17x8 +35 didn't clear coils but the 17x8 +25 did??? doesn't a lower offset put the wheel/tire deeper into the wheel well toward the coils??
I've gotta be missing something...
SeVa-S13
Car: '05 GTO 6spd
zerothread?id=153806
Read. about 2/3 of the way down. Then hit up the other Suspension forum FAQ's.
Research *before* purchase = mmm mmm good.
IveBeenBad
SeVa-S13 wrote:zerothread?id=153806
I really hope your not talking to me, because I researched.
nismofly
Car: 89 Nissan 240SX Hatch
hes just telling Pencil Shavings where to look for offset info, see the post 2 above yours
17x8 +25 will stick out of the wheel well 10mm more than +35, the higher the offset the more it sticks in towards the coil
structure says +35 wont clear but he was running a 235 tire
run a 215/45/17 and youll be fine for clearance Pencil Shavings
i have a question for you though, IveBeenBad, whats a 225/24/17?
PencilShavings
Car: '91 240 hatch
Thanks guys. I've read that sticky before and understood it in terms of how the measurements were done...I've been thinking about it backwards when its on the car the whole time though
Juujai
i agree with seva. even for conservative guys i'd go atleast 17x7 +15 or something. but i guess that isn't a choice being 4 lug or going with 5zigen. not going wider but lower offset is the key. i'd do atleast the 17x8+35 with maybe a sandwich to be conservative atleast.
IveBeenBad
nismofly wrote:i have a question for you though, IveBeenBad, whats a 225/24/17?
lol i fixed it... meant 225/45/17.
Just to let people know my reasoning for this wheel:
It fits big brakes and coilovers (coilovers need a spacer but fairly small one)7" wide tires should be more than enough for most people, so unless you make 350hp traction wont be much of an issueFor the money, it's hard to find a wheel that fits better, and anything over this size gets pricey to put rubber on
