ExampleJeff Williams wrote:The big factor in rolling the fenders, is the tread width, and the centerline of the wheel. If you have 10.5" wheels and 275 MM tires, you would have more fender clearance than if you had 10" wheels and 305 MM tires.
The key, is the centerline of the wheel.
They dont have the offsets determined yet. I think on the the 22x9 and 22x10 they want to go with a +32 offset. But I want the 22x9.5 and 22x10.5 so I can have a bigger lip and might use the same offset.PIONEER wrote:I like the wheels.
on 22" with a 295 tire I'm afread its going to rub on your F50. What Offsets have you ordered. I think the F50 can fit 10.5 rims with +40-45 Offset on 275 Width tires without rubbing.
22" brings the rim too close to the strut and fender that there's not a whole bunch you can play with the Tires. On a 19-20" you have a little more rubber so it can be pulled in a little with negative camber.
I'm looking at some Lexion 203 or 401 now in 19" with a 19x9 19x10 setup. Found some great prices, just waiting to pull the trigger.
To be honest, I can't see any indication of that wheel rubbing??2005Q45inCali wrote:You can tell the fender is rubbing on that wheel. I'm suprised they didnt roll the fender on the Axis Q
I seriously doubt that the 40 to 45mm offset in a wide wheel width is going to work - you will most likely hit suspension components.PIONEER wrote:on 22" with a 295 tire I'm afread its going to rub on your F50. What Offsets have you ordered. I think the F50 can fit 10.5 rims with +40-45 Offset on 275 Width tires without rubbing.
With 22" wheels, an offset of +32mm might work out where you do not need any rolling, but I would be very surprised. I think you will prefer to roll so that you do not have tire contact with the fender.2005Q45inCali wrote:So now I just decided to go with the original plan which is 22x9 and 22x10 and offset will be +32 which they gurantee will fit with no problems which includes not having to roll the fender.
I going with the 10" width instead of 10.5.. the guys at GFG insist there should be no rub but we will see.PIONEER wrote:on a 22" wheel with +32 offset and a 285 or a 295 tire it will rub on the fender side I'm almost 99% sure.
My 285 with a +38 offset were borderline and the hair on the tires would rubb when I went over big humps in the road.
the 10.5 with a 285 or 295 will rub for sure. I don't think the problem is the Rim. The problem is your choice on tire size. on a 10" with a +32 I think 275 will be a good match.. but Its tough to put a 275 tire and keep the speedo in check. Thats why I went with 285 in my old setup.
