I am taking it to the shop regardless but I want to be prepared for any BS the mechanic may throw my way. Any help would be greatly appreciated.
Water can sit there after rain or washing the car if it is not driven or driven at slow speed.Minus (-) wrote:i noticed a leak almost similar to that, but more on the left side like under the windshield washer fluid and coolant tank...i was able to get on the floor and stick a paper towel in the hole underneath. It was colorless and odorless. i took it to nissan and they said i had no leaks,scrapes or bumps under. Saw it again next morning but not as much, so i went back and again they say no leaks...My coolant was at MIN and the tech filled it to Max....the tech says sometimes water can sit there...Is that true?? is the bottom of our engine compartments always bone dry??? and if that is transmission fluid in my car, what smell and color fluid should i be looking for??? and to the OP, did you notice any difference in your car to make you check that area in the first place??
08 M35X 75K
what a relief!!...Good looking Dean, you always come thru in the clutch!.....i ended up gettin a free coolant fill. I went for an oil change, told them my problems...and i asked them if they fill the coolant when "topping off fluids"...went home and checked and saw the water again....went back to the dealer and they apologized for not topping off..lolDeanM45 wrote:Water can sit there after rain or washing the car if it is not driven or driven at slow speed.Minus (-) wrote:i noticed a leak almost similar to that, but more on the left side like under the windshield washer fluid and coolant tank...i was able to get on the floor and stick a paper towel in the hole underneath. It was colorless and odorless. i took it to nissan and they said i had no leaks,scrapes or bumps under. Saw it again next morning but not as much, so i went back and again they say no leaks...My coolant was at MIN and the tech filled it to Max....the tech says sometimes water can sit there...Is that true?? is the bottom of our engine compartments always bone dry??? and if that is transmission fluid in my car, what smell and color fluid should i be looking for??? and to the OP, did you notice any difference in your car to make you check that area in the first place??
08 M35X 75K
Transmission fluid will be oily (slippery) and reddish in color.
