Just need help asap plz!
nismodk21
Car: 89 240sx
ok i just upgraded my sr with the gt2871r..it has some kinda fuel prob now i think..im smelling gas like crazy and it just doesnt seem like it has the power it should have..i have 80 miles n im already close to 1/2 tank. this mornin i tried starting it but it was struggling..like it had to much or not enough fuel in the system..i need help asap plz
Sleeper_RMS13
Car: 91 FB W/Blacktop SR
Check your whole fuel system: injectors, lines,fuel filter and fuel pump. If you had a full fuel tank and drove 80 miles and now have half a tank, then you definatly have a leak somwere. If your power band feels hesitant then obvously your not getting enough fuel to the cylinders because of a leak. So do not smash the pedal at any time or you will will lean out and detonate. Do you have a wide band by anychance?
nismodk21
Car: 89 240sx
ok ill do a more detailed search..i can only smell gas while im inside the car..just looking around engine n gas tank there is no visible leak. wen i did get into it is seemed smooth just didnt have the power i thought it should..seems like my stock turbo had a better pull..ill be ordering one here soon. what is a good one that wont break my bank lol..
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
I have the same problem. I get 60 miles on 1/2 tank. EXCEPT I don't have a gas leak I had already fixed mine. But with the fuel mileage issue I am having the same thing and need advice as well. My injectors, MAF are both good. New fuel filter all new fuel lines.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
If al you repaced was the turbo check the exhaust gasket Between turbo and mani. Also take it to a shop that has a smoke machine and have all your pipes checked for leaks. I just did this and found leaks that I swore were not leaking! I fixed the leaks and my car is now the fastest its ever been.
nismodk21
Car: 89 240sx
to compactfean..well i do know i have a small leak n my exhaust right before the muffler but would that rrly be wats causin my prob..i have a air/fuel gauge..its not wideband but i was told if u hit gas n it goes to rich im fine n if it goes to lean turn it off..since the new turbo it wont come off the lean unless its at idle right after i start the car.. how can u check fuel injectors n whats a good low price wideband
Sleeper_RMS13
if you have any exhaust leaks before the o2 sensor then it will throw it off and cause you too run a little richer but i dont think thats your case..when you swapped to the 71 trim did you change injectors at all? An how acurate is your fuel gauge? I know mines goes 80+ miles on an empty tank. and as for wide band goes look in the clssified section here on nico youl get way better deals then buying brand new from a store.
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
what injectors, fuel management are you using? Are you using a compatible fuel pump and is your FPR functioning properly? All these things will help people determine what you should be looking at.....Who-ever sold the AFR gauge to you was just trying to move a useless product, unless it is a wideband it will not do anything for you.
nismodk21
Car: 89 240sx
well before i swapped turbos i could go amost 100 miles with out the needle even movin..i was told by zerolift that i can keep everythin stock as long as i stay at the 7lbs mark..if i want more boost id have to go get a tune but they said i can keep stock injectors n maf..i have the walboro 255 pump other than that everything fuel wise is stock..
240life
Thats not safe to run a 2871r at 7psi your still to close to maxing everything out...maybe a s14 t28 but def not a 2871r. Your not feeling the power due to extra turbo-lag because the 2871r is huge compared to a s13 t25. You NEED 550 min injectors and a new maf, you also NEED to tune you pcm to compensate for the added fuel/ air. once you do that you will be able to up the boost and enjoy your turbo. Your using more gas because your maxing out all of your fuel system, and your probably always in boost.....Also change your FPR, stock ones fail when put under the stresses of a larger volume fuel pump. The gas you smell in the car is probably a bad tank seal from when you changed your pump. I run 740cc inj, N62 maf, 2871r .62 with a emance tune...during boost I get like 10mpg on the highway out of boost in 5th gear I get close to 30mpg.
Modified by 240life at 1:53 PM 2/22/2010
nismodk21
Car: 89 240sx
then if thats the case then zerolift needs to go out of freakn business cuz they dont know wtf there doin..ive gotten more hlp off this site in just these posts then i have from zerolift n 2yrs..well my main prob was i had a hole in the cuppling that comes off the turbo..i think that has fixed my major prob..i do plan on gettin new injectors and maff..wats a good decent price injector set..does anybody know of a shop good with sr that is in the dayton cinci, ohio area..
compactfean
daily
You can get some ebay injectors for cheap. Someone correct me if I'm wrong but a lot of the after market injectors are made by the same people. When I was big ballin I just got the tomei 740's.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Definitely get quality parts for your fuel system especially FPR. I'd do a quality tune as well such as JWT. I personally have had bad experiences with E-mance.
nismodk21
Car: 89 240sx
i just put a gt2871r on my sr..it get to about 10lbs of boost..when i hit the gas 90-100% it cuts out..i need to know y n is it bad or what..im running stock fuel system..zerolift told me id be fine as long as boost stays to 7-10lbs..im lost
Justin35ll
Car: s13 coupe sr20det
You guys can't just swap a bigger turbo on without leaving the stock fuel system.It's common sense if you're adding more air you need to add more fuel
Your engine is cutting out because it's running too lean and it needs more fuelGet bigger injectors and a tune
240life
I put a wicked big turbo on my engine and it blew up eventhough the guy who was trying to make $ off of me said it would work...Im to dumb to figure this out please help
nismodk21
Car: 89 240sx
k will a wideband an a safc2 hlp for now or am i screwed till i get bigger injectors...ugh zerolift needs shot between the eyes..they freakn blow
