VNG704 »
https://forums.nicoclub.com/vng704-u103769.html
Fri Nov 27, 2009 11:10 am
So I was at a stop light engaging the clutch and shifter in 1st when the light turned green and the car died. At first I thought I may have stalled the car but it wouldn't even crank up. I thought battery so I closed my windows and nothing. They don't work BUT the radio comes on, the lights work, power door locks work. Oh and it's a nearly new battery. Had car towed home. Checked battery connections, they're good. Checked any and all fuses that have anything to do with ignition, battery, starter, egi, fuel pump, p/window, etc... and they're all fine. When the key is in "ON" position, there is no fuel pump whine-up. I almost think it's the alarm disabling the fuel pump or something. I enable and disable the alarm, still nothing. Maybe the stock alarm(?) which I don't have the alarm fob for. But isn't that impossible since all this happen while the car was on and running? Could be the fuel pump died on me but that wouldn't explain the windows not working. Would like to figure what the deal is but at the moment I'm worried about the window being open. Disconnected the battery for some time and reconnected to reset things but car still won't crank and windows don't work. Shooting in the dark here. Any help is appreciated. T.I.A.
