platez808 wrote:Hmm. So you were using the stock tach with no mods. Did the readings on your tach and boost controller match up?
Yes, I know how to do exactly what LS AUTO does to convert S13 clusters to read the R33 signal. It is just adjusting a potentiometer, and matching it up with something that reads accurately. My Boost Controller and Gauge cluster were always the same within 50-100RPMS, but that is close enough for me.
platez808 wrote:Any way, thats really weird that the signal just disappears and your ecu is fine. If anything just go nuts with the multimeter when you have the chance and check everything that way. I dont know the range for the tach signal and i'm actually out of the country for vacation right now so i can exactly poke around at my car to figure out. If you can get your hands on another working ecu then i say you try that, even if you borrow it.
My ECU looks perfectly fine though, look at the 6 resistors in a row, then the 2-3 on top of that are right above it in the PIC, I believe those are for the TACH. They look okay top and bottom.
platez808 wrote:In terms of the tps wiring, i'm sure that you should be taking the signal from pin 38 red wire with blue trace (R/L.) Well that is where i'm getting the signal for my AVCR anyway haha. And i was reading up on the wiring for the evc 6 online and from what i saw then the throttle position wire on the boost controller side should be white (and not white/black from what it looks like in your picture) but thats just what i read.
Pin 38 is labeled as Throttle Position Sensor "Sense", so it that basically the OUTPUT pinout? If so, I will wire it up to that one, because it's not wired up to that currently...I think it's actually on Pin 48 (Regular Throttle Position Sensor -> input??), so I'll change that.
Also, on page 23 of the U.S. manual for the HKS EVC 6 it actually stated that the "Throttle Input Signal" is meant to be used as the BLUE wire, and the Speed/RPM Input Signal is supposed to be white. I have not changed the wires around, and like I said it all worked before, so I believe something is loose there, or maybe my CAS is going out...
Photo Attached:
I believe the lack of a proper tach reading to the HKS EVC's stepping motor is the cause of some of the other issues...
Thanks for the feedback, I will do be able to do more diagnostics Sunday or Monday.
