elwesso wrote:
no... which is pretty stupid!!! the factory ones are pressed in studs, and you cant really get em out.
Wes beat me to it... I had typed this earlier but was so busy at work I'm just getting to post it now...
rsiwicki wrote:I know this is a stupid quesiton, but do I need the nuts for the bolts also or can I reuse the factory nuts? I think I have the bolts in the setup I have got, but not 100% as I am away from my car for the last 4 weeks.
Riswicki....Nothing stupid about it. Stupid was when I was using a hammer to try and bang the studs out of the factory Rods. I gave Wes a call and he set me straight. Are you switching to an after-market rod? You can reuse the factory nuts. You'll need four 17 mm bolts if they were not provided though. Rougly 1.5" long is good.
Sardar.... check out the pics. I didn't press in any rubber. I removed the entire rod and replaced with Stillen solid tension rods. You jack up the front end, place the car on stands, then pull off the rods. There are three 17mm nuts to pull on each rod for removal. Putting in is just the reverse. The plastic engine shield may need to be pulled a little and bent to allow access to the tension rod nuts facing the front.
If you plan to go OEM, you can purchase the inserts, press out the old rubber and press in the new. I suppose you'll need a shop to do that part but do the rest yourself and save some $$$.
...Drew..
