TurboKA37 wrote:which gauge brand do you have? i have the autometer oil pressure gauge im going to install and was wondering if you used some adapters and splitters to retain the oil pressure switch
Autometer Lunar Mechanical Oil Pressure. For the adapter(s) I recommend going with McMaster-Carr. I only paid 16.78 including shipping for the 1/8 BSPT to NPT adapter going into block. The 2 1/8 NPT FxFxM Tees. And one 1/8 NPT to BSPT adapter for the original oil pressure switch. Clearance is good too, I'll have some pics up here later. If you want your setup like mine part nos are:
http://www.mcmaster.com/
50785 K219 - Extruded brass threaded pipe fitting 1/8 FxFxM, Tee4092 K26 - 316 SS Threaded precision pipe fitting 1/8 BSPT F X 1/8 NPT M 4092 K11 - 316 SS Threaded precision pipe fitting 1/8 NPT F X 1/8 BSPT M
Nathan wrote:Yeah, is it mechanical or electrical? I'm guessing mechanical from your question of bleeding it. I prefer mechanical, electricals suck (I had a bad experience).
Yeah, its mechanical. And I actually got to do some extended highway driving and it still sits at 40PSI like a rock. 50PSI city crusing and 60-65PSI hiway driving.
