joe603 »
https://forums.nicoclub.com/joe603-u34652.html
Fri Oct 20, 2006 5:15 am
The band aid statement is mostly true, but what the CAP does, is store power for dynamic bass hits, while maintaining a constant current draw on the car's electrical system. Because of this, it stops some of the abuse that hungry bass amps will inherently do. The battery is another key component in the system. A battery designed for heavy current draw from stereo systems will help with the problem, and last much longer than a stock one. Yellow topped Optima's are a good choice. I would start by replacing the battery and installing a 1F Cap. If you still run into problems, upgrade you're car ALT. With compitition systems, an additional battery is usually required to keep up with the extra load as well as ALT upgrades. This is the price for BASS!
