i just installed my s-afc to get my z32 maf to work in my red-top sr20det. it idles fine and runs good. i have a couple questions...
is the s-afc always suppose to be on? even with my car off the s-afc disaplay is still on...i can go through the menus as well. i bought this unit used off ebay so am curious to see if its defective and mightve been sold because it doesnt turn off.
all i have changed settings wise is the 2 in and 6 out to get it to run. i have not corrrected any air flow % at any RPMs. i was wondering if the 2 in and 6 out setup is generally efficient enough. does that setup run a lil rich to be on the safe side by default? is there any standard corrections people use if they know the 2 in and 6 out setup runs too rich or too lean at certain RPMs? (i have stock injectors, FMIC, z32 MAF, z32 fuel pump, HKS intake, turbo extension, downpipe, full exhaust, no cat)
i know getting it dynoed with a wideband and EGT is probably the best way to tune it... but i just want a quick, safe and easy tune since i just got it installed and don't have the money and time to get it dynoed anytime soon.
