tokendog »
https://forums.nicoclub.com/tokendog-u83450.html
Mon Oct 13, 2008 9:58 am
Alright, I checked out Positron_'s build, Idaho's, and read up on installing the CAS (S15 FSM) and I think I might have got it right but I was hoping someone on here with more experience could verify that I got it right. I did this with the crank starting at the second notch from the left.
I turned the crank over a few times and heard no mechanical noise or clanking so I guess thats a good sign. I did notice the chain will tense up and then have slack in it as I rotate it. Is this normal?
Thanks in advance guys. All I have left after this is coolant hoses and putting the rocker cover back on.
Intake side cam gear:
Exhaust side cam gear:
CAS gear (for some reason my marks seem reversed. On Positron_'s post, the first dot is up and the second dot is down):
and both intake and exahust gears together:
