Just installed a intake, now my car immediatly dies!!!
S13ChucKAT
Car: asd
1990 240sx, I installed a cone filter/maf adapter, and now when i start my car, it immediatly dies, unless i hold the gas.. and when i rev, it stops at 2600-3000rpms!.. what did i do wrong?!... I didnt throw the MAF around, it didnt bang around (that im aware of). no water got in it.. all the hoses and connections are sealed shut and tight.
is my MAF blown?
s13sr20chris
something is def wrong with your maf. go over your connection and if necessary check for power, ground, and signal.
navysnail
move the harness conector around a little, wiggle it if you can (gentlly)
when my car was running like that, i accidentaly bumped it with my hand and like magic, the engine went from trying to stay alive to a rock solid perfect idle
S13ChucKAT
Car: asd
well, heres what entailed last night
I went out and took the MAF off, brought it in, and cleaned the Outside of it with mineral spirits.. checking for maybe holes/cracks.. got it cleaned OUTSIDE, and went back to the car, pluged it up, and it runs like normal.. so I dunno whats up with that.. Now i got a new problem..
The car has a fuel cut at 5000rpms in 4th gear.. thats it.. 1,2,3,5 all fine.. but in 4th at 5000rpms, the car suddenly just stops revving,, then it slows revs down to like 3000 rpms, and returns to normal.. i dunno WTF that is about
navysnail
that is completely normal just so you know, all nissans do it, it can be removed but i dont know why i would, 115 is plenty fast for me, lol. honestly, its there for your own safety, but if you must have it gone, do a search in 240 technical section, i know it has been discused numerous times
S13ChucKAT
Car: asd
my speedo doesnt really work.. at all.. but at 5000rpms in 4th, i dont think im going 115mph.. if i am.. then.. eek
navysnail
well i know that 5k in 4th is when the ecu cuts fuel to the engine, its normal, nothing is wrong with it
S13ChucKAT
Car: asd
wow.. i guess i never noticed.. Hmmph.. Coolness thanks!
S13ChucKAT
Car: asd
WEll, nope, its not just in 4th gear.. it happend to me today in 5th gear, crusing at 80mph.. its got to be somethign with the MAF..
navysnail
if it runs normaly in the other gears then its not the maf
leme think for a few minutes on what else it could be...
s13sr20chris
what rpm is 5th? i have heard of ecm fuel cut failsafe. i heard something about with a faulty speed signal it would do it in more that one gear or something.
S13ChucKAT
Car: asd
then thats probably it.. because my speed sensor goes koo-koo everyday.. and it happend to me today, i was in cruise at 70mph.. then the speedo spun all the way right to 120mph, then my cruise turned off. and did that damn rev fuel cut crap.. So speed sensor smells like the problem?
s13sr20chris
sensor or speedo head. the signal goes from sensor to speedo to ecm. you can test the sensor by spinning with drill motor and looking for ac voltage. prob speedo head though.
NateDogg
I had the same problem and it ended up being a faulty gauge cluster.
s13sr20chris
i have actually seen quite a few speedo heads go poo. mine went twice.
S13ChucKAT
Car: asd
I dont know if it helps.. but the speedometer works 80% of the time.. maybe 90%...
sometimes it will stick to 0.. and other times it maxes out to like 125mph.. depends.. if im going over 70mph, it goes higher.. if below it dies to 0
navysnail
maxes out at 125 when your going over 70? that sounds like the problem
