Postby
Carl H »
https://forums.nicoclub.com/carl-h-u9196.htmlFri Oct 12, 2007 7:33 pm
check the ignitor, you know how that connection is...might have gotten a bit shifted.also check that there is power to the coils, if the ecu powers up and turns on then there SHOULD be power to the coils (the trigger for the ecu is also the trigger for the coils).if the motor has gotten flooded out then you need to pull the plugs and let it air out.
