TheKryptKeeper »
https://forums.nicoclub.com/thekryptkeeper-u55651.html
Tue Jul 31, 2007 11:43 am
I blew a head gasket. I replaced the head gasket. I had the head milled .031 in and the valves compression tested. I didn't shim the head and instead settled on raising my compression. I put it back together and cranked it by hand to ensure that the valves didn't touch. They didn't.
I cranked it over and it didn't start. I did a compression test and every one of the cylinders was at 40psi exactly. That's when I saw that my timing was off by one tooth. I fixed that and cranked it and it didn't start. I now had 50-5-5-45 psi respectivly.
I ran out of ideas and equipment to check. So I towed it down to the mechanic to be diagnosed. They just called and told me that I had 50-42-35-25psi respectivly. They got an 83% leakdown on all cylinders, 1 and 3 intake, 2 and 4 exhaust. They say it's either my timing, or my valves are bent.
I had my valves checked and I'm pretty sure that my timing is on. (I stuck a straw into #1 and watched the valves open and close in time; they're dead on).
My question:
What the hell?
Thanks,Krypt
