Just got started on a '95 240sx need some tips
eurovisionracing
Car: 1995 Nissan 240sx
Hey everyone, i recently bought a '95 240sx and i was wondering if anyone could give me some quick tips on what i can do as far as cheap and quick upgrades. (i already have an intake and exhaust) Thanks for your help
TurboSilvia7587
what r ur plans for the car...drag, drift or grip?
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Use the SEARCH button in the upper right corner of this window. It's the blinking red button...
You will find out everything you need to know there.
To start, check up on all the basics if you haven't already. Check plugs and wires, distributor cap and rotor, injectors, belts, hoses, fluids, oil...all the fun stuff. I'd even go all out and get an alignment so you know you're starting fresh.
One of the best upgrades you can make are tires (unless you just hopped on the drift bandwagon). A good set of tires will get you better grip, and lower ET's if you are taking it to the strip. After intake and exhaust; you can get some pulleys, cams, head work...you'll know after searching.
Above all plan out what you want to do with this car before you start buying misc. parts. Are you going to go turbo, stay NA, use it as a daily driver or a weekend racer...
eurovisionracing
For now im planning to drift, at least until i can save up enough money for a swap...thanks again for your help
eurovisionracing
im also doin a major tune up...i read that i could drop a z32 300zx fuel filter in...is it better?
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
eurovisionracing wrote:im also doin a major tune up...i read that i could drop a z32 300zx fuel filter in...is it better?
yep a z32 fuel filter is the best bet if ur replacing the fuel filter, its bigger and cheaper (cant lose )
direct bolt on
97ka-t
Car: 1996 Nissan Maxima
1998 Nissan Altima
No problem to put Z32 MAFS in your car. This will not help you gain anything unless your car is turbocharged above 300ish HP.
EDIT: That's what I get for being here @ 1230AM, I thought you said MAFS. My fault.
