Just got some zeals for my s14 (56k-at your own risk)
steve s14
just purchased a set of zeal function x coilovers for my car and thought i'd share some pics of the install.
the victim
before rear leg transplant
after
before front leg transplant
after
after the operation, the damn front wheels didn't fit anymore i bought some wheel spacers and now it's fine.
Modified by steve s14 at 2:41 PM 9/19/2005
kamikazestorm420
pics dont work
steve s14
sorry, damn imagestation wouldn't allow the link to stay up.fixed now.
swwifty
*drool* where did you get them? I'm contemplating between buddy clubs and zeals.
steve s14
the quality is really good, i went with the zeals because of the features and the brand name reputation. i figure if i'm going to slap down that kind of cash, i'm going to go with the best i can afford.the rears are 30 way adjust, standard monotube, steel shock body for reliable street use.the front's are 30 way adjust, inverted monotube for extra rigidity, steel shock, pillowball with adjustable camber plate.the x coils have really linear spring rates and cause the car to ride very rough on the street. spring rates are 8k / 6k - front / rear.the ride is not kidney busting with the shocks at the softest setting and is actually not that bad. i have them set at 10 rear 7 front and it's noticeably stiffer. unlike other coilovers that have 15 or more way damping adjust, each click of the dial actually makes a difference.overall i very happy with them so far.
swwifty wrote:*drool* where did you get them? I'm contemplating between buddy clubs and zeals.
check my sig, that's where i got them.
574-240sx
Car: Nissans, Toyotas, Subaru
Very nice. Zeals are expensive.
kepani
awesome job steve! the zeals look a1 steaksause good!
kepani
hannibal
Car: Red Line to Glenmont
Why didnt the wheels fit after installing the coils? Where were they rubbing? The coilover spring looks so much smaller than the huge factory setup, its hard to imagine how your wheels fit next to the stockies, but not the coils.
chmercer
the wheels are positioned next to the spring assy instead of the shock body like with a shock and spring setup.
swwifty
steve s14 wrote:check my sig, that's where i got them.
I checked their site, but I don't see any listings for Zeal. Do they carry all the Zeal models for the S14? Mind telling what you paid for yours?
steve s14
yeah, like chmercer stated, i thought i could get away with it but i ended up needing a 5.5mm wheel spacer to clear the tire from the coil and lower spring perch and even then it's still really close to the tire. i'll post more pics of it when i get home.i read the instructions, but thought my wheels are aftermarket and therefore it may clear but they didn't. i don't like having to run wheel spacers .i have 17x 8.5, 22 offset on the front with 255/45/17's, if i put on a 245/45/17, i'll have more room between the coil and tire.
swwifty
wow, thats a huge front tire. what are you running on the rear?
badass69
nice coilovers...may I ask how much? spring rate?
kepani
badass69 wrote:nice coilovers...may I ask how much? spring rate?
steve s14 wrote:spring rates are 8k / 6k - front / rear.
that would be kg/mm. conversion from kg/mm to lbs./in. would be approx. 56. example: 8 kg/mm = 56 x 8 = 448 lbs./in.
448 lbs./in. - front spring rate336 lbs./in. - rear spring rate
kepani-who anxiously awaits profile pics of the beast.
steve s14
swwifty wrote:wow, thats a huge front tire. what are you running on the rear?
on the rear i am running a 17x9.5, 38 offset ... 275/45/17.i just purchased a gt35r turbo and felt i needed a good sized rear tire to handle the power i'm planning on having on tap.
thanks kepani for clearing up the spring rates for me. here is a pic of the back end.
180fan
Car: 89 fastback
Did you end up getting them from a guy named Rishie or Josh by any chance?
steve s14
no, who are they?i got them for a good price. the price for them is $2,855.00 normally minus shipping.i got them for $2,584.00 including shipping.
180fan
Car: 89 fastback
Ok nm. Cuz Rishie's the distributor for Endless/Zeal north america but he's a real jerk. Did some local sales for him and damn, a real jerk.
slipnfall
Car: '06 D40
yum, I like those wheels: are they gram lite 57's? Do you have a webpage?
