just got some s14 fogs ... a little confuse on how to install
yessir240
Car: s14 zenki
Well Just bought the Zenki Fogs and I see how to mount them but what do I need to do to get the things working... and do i need to wire them to another switch ...thanks
yessir240
Car: s14 zenki
I have a base model 96
Adikt
the harness's should be right there and if you wanna get them to work get the stalk switch from an SE
KDashy
Car: '97 Nissan 240SX
Yes, you'll need the SE turn signal stalk that has the foglight switch on it, either get it from a junkyard or from the dealer for about 90 bucks.
Then you need the foglight relay that goes in your fusebox under the hood, either ask your local dealer or lookup an FSM for it. Best place to get it is the dealer, about 15 dollars, although I hear you can get it from auto parts stores for half the price or less, assuming you know the part number and exactly what the relay looks like.
yessir240
Car: s14 zenki
Im thinking I will wire the fog lights to a different switch and place it in a consealed location so i can turn them on anytime
GrilledCheese33
Car: 2008 Nissan Xterra
1972 Yamaha R5
2017 Sea Doo Spark Trixx
where did you get the lights? I have one that doesn't work, and if you don't mind me asking, how much did you pay?
KDashy
yessir240 wrote:Im thinking I will wire the fog lights to a different switch and place it in a consealed location so i can turn them on anytime
Thats actually not a bad idea since you have to have your headlights on to have your fogs on.
I got my fogs from a fellow nico member for 40 bucks.
Ramius83
Car: 1995 240sx SE
You can turn your foglights on at anytime, just do the re-wire for it.
Go to google and search for Maxima Foglight re-wire. Follow the same process, using a multimeter. You can turn them on anytime, regardless if the main headlights are on or not.
