just got new wheels, what size tires should i get?
DrifterXRPS13
Car: 1993 Acura Integra LS, 1998 Nissan 240SX SE 5sp. KA-T,2004 Honda CBR 600RR, 2005 Suzuki GSX-R 600, 2013 Harley Davidson Iron 883, 2014 BMW S1000RR
hey everybody, i just got a set of new wheels..well not new but their used and i got them for a good deal, all 4 plus used tires for 40 bucks!...
well a little about the wheels, their 16x7, the offset is 35 on all of them...first off is this gonna sit flush with the car or is it gonna stick it out ghetto style?....second, the tires that came with it are 205/50/16...wondering what size should i get?...i was thinking about 225/50/16...but then again i don't really know much about wheels and tires sizes...so if you could enlighten me i'd be much obliged, thanks for your help, peace
chmercer
its gonna be sunk and if it was me id get 205/45s but then again i dont care about load rating
SmithSR
Car: 240sx
205/55-16 is same as OEM225/50-16 diameter is also OK
The 7" +35 won't be flush or stick out, but it would be gay if they did either anyway.
So we had trouble fitting a 225 width on a 7" +35 wheel onto the front of both my car(coilover) and my friend's car with KYB struts.
We had to do 205/55-16 to clear the Front strut, and on the back we did 225/50-16.
225/50 would be my choice as well.
DrifterXRPS13
thanks for the input guys, i'm gonna order bfg g-force sports, pretty cheap from tire rack, good tire from what i hear too, should i go that same size all around or smaller up front?
edit:btw, i have stock suspension, but plan on dropping it within the next month or two
nismofly
Car: 89 Nissan 240SX Hatch
how far do you plan on dropping it? if youre just using springs then keep the same size all around, but coilovers might present a problem like Smith said
If you order from TR, make sure you go through the link here on NICO...
They help keep us afloat!
gogg
Car: 89 240sx silver hatch (burrito)
what do you plan on doing on these tire/wheels? drift, drag, autox, daily?
DrifterXRPS13
well looking for just daily, but i got a problem,...i went to put on my wheels today and they don't fit, i'm so pissed,...they're a 4 lug universal pattern but i guess 4x114.3 isn't one of them!....the thing is that i get one hole onto the hub, and the other 3 are so close to going on, i mean, it's like the size is 4x113 or something crazy like that, i was wondering could i just redrill a milimeter or 2 in each hole to widen out the spacing?...if so should i do this myself, or take it to a machine shop? thanks
SmithSR
Car: 240sx
You should NOT drill yet another set of holes.What will end up happening will be holes shaped like an hour glass and as you tighten the lugs the lug nut seat will deform. In time the lug nut seat will fail and your wheels will fall off.(worst case scenario).
No machine shop around here will do what you're asking due to liability.
DrifterXRPS13
so what your saying is i'm pretty much sol, unless, what about adapters/spacers, that change the bolt pattern?....would those work, sorry for all the questions...
