evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Apr 27, 2007 7:18 pm
sounds like you need to get it to a reputable shop and have it looked at by a qualified trustworthy source, the loud exhaust could be any one of a number of problems, the smoke, well, smell like gas implies rich which would normally accompany black smok, bluish smoke indicated oil burning which would be an internal engine problem not fixable with silicone and quite expensive to fix, white smoke generally means coolant buring which means blown headgasket which means open your wallet, as for an oil leak under the car could be any number of sources, most common is the cam covers, still a huge PITA to fix, only takes silicone and 4 hours to tear the engine down far enough to get to them!
