C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Fri Jul 11, 2003 11:18 am
to lock each section down, you tighten the bolts that hold the housings in place. In the lower picture, the bolts on the back of the compressor section with the brass-colored piece linking each pair of bolts is what you will tighten down. The turbine should have something similar. It should hold fine, but if you are worried about them backing out, you can get a part from a turbo supplier that is similar in shape to the brass-colored piece, but made of thin metal. It has tabs that you bend up against a flat side of the bolt to keep it from backing out.
