Just got my turbo. Oh o
S13Sil-line
Car: Full throttle-*** out sideways
I cant bolt my turbo up to my manifold. The turbine housing is touching the manifold and wont let the flanges sit flush. It's a T3/T04E. What should I do???
SeVa-S13
Car: '05 GTO 6spd
Lots of gaskets. :D
S13Sil-line
I just loked some more and the oil and water lines are a little different. Any more advise.
Nameless EJ6
Car: What the **** do you think.
You gotta be creative. Gaskets or spacers for the turbo. Different lines (stainless etc) for the feed.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Clock the housing and start shaving down where it hits the manifold. take a lil bit off the manifold and the turbo housing.
From what I can tell it dosen't look like much has to be shaved off.
BoostFab
Car: S13cp, S13fb, S14z
try to rotate the housing, or using an adapter....topmount? ;)
FAST-DATSUN
spacer and two gasket with longer studs!!!!!!!!!
S13Sil-line
I kinda like that top hat adapter. How much???
BoostFab
you meant the top mount adapter i made? it's NOT a Top Hat!!!!
S13Sil-line
Ok, how much from you if you were to make one?
klattr1
Car: GT42R powered S14/KA
you could use a "weld on" t3 turbine flange and use it as a spacer instead.This one from Forced Performance is $34 and its 1/2" thick. should work good.
How much room do you have on the right side of the turbo from clearing the firewall?T3 flange
BoostFab
S13Sil-line wrote:Ok, how much from you if you were to make one?
if you're interested, email me and we'll discuss, i can make you one for cheap. stainless or mild steel, your choice. (your cost probably near double the cost of a flange above)
