What speedo cable are you talking about?600-1300 for 5spd conversion, where did you get that price range from. For that much you can get a really cheap motor set if you look really good and shop around.24j0hn wrote:for the cluster try getting the speedometer cable looked at... either its disconnected or broken thats most likely the problem... and a 5-spd swap is definately worth it, all together it'll cost $600 to $1300...
Thats what i was thinking,i just sold my 5spd transmission for 100$.All you need then is your lines and resivor and your pedals.placham wrote:
5spd maybe 300bucks at most.
Yeah and if your lazy, you can get braided clutch line from master to slave, don't know how much those go for but think like 85 S/p sounds about right.Trans about 150 (with sensors, and drive shaft) New clutch depends what you want here, but a good one for DD car Don't think would cost any more than 150, and Flywheel, if you get from Salvage yard with trans what are they like 25 bucks.Thats like 400 right there, and you'll need pedals and master I'll be generous and will give you 100 bucks here.So like 500 bucks gets you 5spd, if you shop around you can bring this down quite noticeably.leesredgt wrote:
What? no, mine went out and I replaced it with and analog cluster and it works, like most Digital clusters probably a blown capacitor or unit. $283 +shipping from http://tinyurl.com/8oaasoand there was a guy on ebay a little while ago that was fixing them for $170 but i can't find a link right now.24j0hn wrote:for the cluster try getting the speedometer cable looked at... either its disconnected or broken thats most likely the problem...
and a shift boot, and the manual drive shaft, idk bout the transmission mount, but i don't think there's any TCU or wiring needed other than the speed sensorleesredgt wrote:Thats what i was thinking,i just sold my 5spd transmission for 100$.All you need then is your lines and resivor and your pedals.
No. just wait and save until you can do/afford a 5spd swap. And please don't do anything stupid to that car, that **** is so fresh and so clean.rbcardz wrote:So for the time being, would a cold air intake give me a little performance increase?
Please do not give advice if you don't have a clue on what your talking about. 240's have electronic speedometers. So that means that they do not have a cable. There was recently a topic about this kind of stupid posting. A 5 speed swap will not cost $1300 and if yours did they saw you coming.24j0hn wrote:for the cluster try getting the speedometer cable looked at... either its disconnected or broken thats most likely the problem... and a 5-spd swap is definately worth it, all together it'll cost $600 to $1300...
